Re: Farmall A Cooling System
Posted by Haas on August 14, 2006 at 14:29:07 from (12.65.30.5):
In Reply to: Farmall A Cooling System posted by Ohio Mark on August 13, 2006 at 19:57:56:
Old is correct!! Your system is working as it should. If the thermosyphon system is not working, you would be overheating and blowing steam in fairly short order. If the system is working correctly, you will really have to do some heavy work to get the lower hose to warm up much. At low load, it will stay cool all the time.
