Re: voltage regulator problem
Posted by John T on August 14, 2006 at 20:01:02 from (66.244.90.5):
In Reply to: voltage regulator problem posted by Charlie M on August 14, 2006 at 16:18:21:
Charlie, it sounds like the VR may have a loose connection or a poor ground or else one of its relay contacts is burned or carboned up or sticking. The first thing I would do is remove n clean n wire brush and reattach each of its connections,,,,,,next check n clean the VR's frame ground connection to the gennys case (if thats where it mounts),,,,,,,,if that dont cure it you might try n remove the cover and NON ABRASIVELY clean/buff/polish lightly the relay contacts in case they are burned or carboned over. You gotta be careful in abrasivley filing or grinding off too much of the silvery coating on any relay contacts cuz then they may go bad. If shes not charging when running but does if you temporarily dead ground the gennys field post to the case, then I suspect either a bad field current control relay/contacts in the VR or else the VR isnt well grounded to the genny or else the wires bad from FLD on the VR to the gennys Field post. If she charges ONLY if you momentarily jump the VR's BAT terminal over to its ARM/GEN terminal, then I suspect the VR's Cutout Relay/Contacts are bad. If either dead grounding the gennys Field post or jumping the VR's BAT and ARM/GEN makes her charge, that tells me the genny is okay and its more likely a bad ground (VR to genny) or a bad VR (relay) or a wiring or connection problem Try this n post back your findings and any questions, best wishes n God Bless John T
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
