Farmall Tractors Discussion Board |
Re: Farmall A engine overhaul
Posted by medfarm on January 23, 2000 at 17:30:33 from (209.162.37.186):
In Reply to: Farmall A engine overhaul posted by Dick J. on January 23, 2000 at 16:38:28:
Your engine will not have to be bored as the dry sleeve wall thickness is thinner by 1/16". The outside diameter is the same. I believe most rebuild kits with replaceable sleeves are a larger bore. Check piston to head/valve clearances if you install the high compression pistons. My only experience with Tisco kits has been with a "M". We installed the higher compression pistons, advanced timimg a slight amount, adjusted carb properly and did some head modifications (valve angle and smoothed exhaust ports, matched intake and exhaust ports to the manifold and increased compression ratio) to the engine. The performance increase was excellant and reliability was not significantly compromised. The "M" engine has 248 cubic inch displacement and produces about 30 to 35 hp. There is room on the Farmall engines to achieve greater performance and still maintain reliability. Good luck Medfarm
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
