Farmall Tractors Discussion Board
Re: Air adjustment
Posted by Rick on January 23, 2000 at 17:31:49 from (63.82.131.147):
In Reply to: Air adjustment posted by Bruce on January 23, 2000 at 15:21:13:
To set the air idle adjustment,First you need to set the load jet first.Turn your air in all the way then make one full turn out .Start the tractor set the throttle at full speed start turning the load jet in slowly till the motor starts to cut out then turn back out slowly till motor smooths out then turn out a quarter of a turn more then stop.Bring motor back to a idle run the air jet in till idle gets ruff then start turning back out slowly till motor smooths out then you got it.You need to check your float level first it sounds like you my be getting to much gas .
Post A Followup
: Re: Re: Air adjustment
