Farmall Tractors Discussion Board
Re: Re: Air adjustment
Posted by medfarm on January 23, 2000 at 17:42:55 from (209.162.37.186):
In Reply to: Re: Air adjustment posted by Rick on January 23, 2000 at 17:31:49:
I agree with Rick. Check float level and needle valve condition first. The float should shut the fuel off when the float is level with the bottom of the carb when the float chamber is removed from the carb. If possible, adjust the hi-speed or main jet while operating the tractor under a load. Pull an implement, stop and make a small adjustment, pull the implement, readjust the carb, note the performance of the engine, I'am sure that you get the procedure.
Medfarm
Post A Followup
: Re: Re: Re: Air adjustment
