Re: fingers pressure plate
Posted by scotty-mn on August 15, 2006 at 18:39:10 from (207.69.137.26):
In Reply to: fingers pressure plate posted by scotty-mn on August 15, 2006 at 14:09:24:
This tractor came from the factory with no t.a. I did adjust the clutch linkage and it is not enough. The old pressure plate someone did adjust the fingers unevenly. I did take the shipping bolts out and there were no nuts as they were threaded into the pressure plate. Scotty
