Re: I've never seen a light switch box like this
Posted by Ron in Nebr on August 15, 2006 at 23:15:47 from (66.252.113.103):
In Reply to: I've never seen a light switch box like this posted by Mike CA on August 15, 2006 at 22:58:46:
Wow- are we the only ones awake tonight????
That's an aftermarket guage. You can order an original(or accurate reproduction of an original) through lots of different old tractor catalogs(which I'm sure you'll be getting) like OEM Tractor Parts and probably even off this website(hint- even if you order stuff off the web, get the printed catalogs too... they make great reading material for the throne).
Don't throw that Stewart Warner away though. Looks kinda old and I'd bet alot of the hotrod guys would bid on it if you put it on ebay as a "vintage hotrod amp guage"....
That push-pull switch just under the guage is aftermarket too- the original IH light switches were roundish and you turned them instead of the push/pull type....they'll be in the catalogs too.
