Re: Super A Front U-bolt
Posted by gene bender on August 16, 2006 at 06:03:28 from (66.43.221.106):
In Reply to: Super A Front U-bolt posted by Mikey D on August 16, 2006 at 05:39:19:
Best thing is first get the threads clean so you can thread easy then you wont have to remove anything. Just stock it thru so only the thickness of the nut is thru. Then after putting top nuts on you can tighten from underneath. Will be fun but can be done. Much easier going on than taking off. Good luck
