Re: I've never seen a light switch box like this
Posted by Mike CA on August 16, 2006 at 08:40:39 from (214.1.211.251):
In Reply to: Re: I've never seen a light switch box like this posted by Janicholson on August 16, 2006 at 05:15:42:
Jim, you said "It has the Starter push button (full starter amp heavy switch) located in it."
What do you mean by "located in it"? Do you mean I just need to remove the key and replace it with the button?
