Re: Glowing M
Posted by Bob M on August 17, 2006 at 09:19:20 from (151.190.254.108):
In Reply to: Glowing M posted by chadd on August 17, 2006 at 08:11:32:
Chad - The red glowing manifold, fire out the stack, etc. is pretty much normal for these engines when worked really hard. However excessive heat and fire can also be from late ignition timing (timing set wrong or centrifugal advance not working), or the carb power screw adjusted too lean. Bad timing can also cause roughness and popping out the exhaust at idle. Timing should be 0 deg (top dead center) mark on the fan pulley at low idle, then advancing to the 2nd mark (32 deg BTDC?) at high idle. ---- You might also replace the spark plugs with a set 1 or 2 heat ranges colder – though colder plugs will be much more likely to foul if the tractor also run under light load/low RPM conditions. Don’t bother switching to higher octane gas – it won’t significantly lower exhaust temperatures. Higher octane is required only if the engine pings/knocks under heavy load. Otherwise running high octane simply empties your wallet a little faster!
Home
| Forums
Today's Featured Article -
What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
