W-30 rods
Posted by Jerry Hulbert on August 17, 2006 at 17:12:45 from (69.215.150.229):
I am just getting a W-30 running and am wondering what the clearance for the rod bearings should be. Being a splash lube, how loose should the bearings be. They seem to be noisy when the hand holes are removed.
