Re: W-30 rods
Posted by Pete in Holland, MI on August 18, 2006 at 08:02:50 from (198.36.89.4):
In Reply to: W-30 rods posted by Jerry Hulbert on August 17, 2006 at 17:12:45:
Have a W-30 and we use 30w detergent oil in it. Have had the inspection plates off during running (interesting to watch, but can be messy). There is no apparent foamin action going on.
My tractor engine was running fine, so I didn't have to crack open the engine.
Did you rebuild your hand brake? Takes a little special attention that I worked thru.
