Re: 1949 Farmall C Bad Rear Axle
Posted by Wayne Swenson on August 18, 2006 at 16:36:46 from (71.13.41.123):
In Reply to: 1949 Farmall C Bad Rear Axle posted by Larry Senter on August 18, 2006 at 16:16:30:
Easiest way is to remove the transmission top to gain access to remove the bull gear from the end of the axle. Makes it a lot easier to replace the gear later.
Securely block the transmission housing, remove the tire & wheel assembly, remove the cap screws holding the axle housing to the transmission, and pull the assembly out.
Replace the inner seal and outer seal while things are apart. Maybe do the other side also??
