Re: Splitting a farmall H (need help)
Posted by kfox on August 19, 2006 at 17:27:07 from (63.18.241.63):
In Reply to: Re: Splitting a farmall H (need help) posted by old on August 19, 2006 at 15:41:45:
If you decide to split the tractor, just remove all the linkage to the engine and block up the clutch housing securely. Hook on to the engine with a hoist/end loader/backhoe/ or whatever will lift the engine. Remove the 4 bolts on each side that hold the frame rails on, and the long, exposed bolt on the rear of the bell housing. Remove the starter and take out the bolt hiding in the hole where the starter mounts. Loosen the four bolts on the front of each side rail and roll the front end forward. (Much easier with two men :-)) You need to drop the rear of the rails a little as you roll forward, to clear the oil filter mounting. With the front bolster & rails out of the way, pick up on the engine until you have the weight, and then pull the dowel pins on each side, close to where the side rails bolted on. I've done this with the radiator on, and with it removed. Its safer for the radiator with it removed. Have fun...ken
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
