Re: Splitting a farmall H (need help)
Posted by old on August 19, 2006 at 15:41:45 from (4.245.2.199):
In Reply to: Re: Splitting a farmall H (need help) posted by RustyFarmall on August 19, 2006 at 14:39:53:
Rusty, I've had good luck with tranny fluid and or turpentine. So far it has worked on 9 out of 10 engines I have used it on. And even the 10th one I had only one piston that didn't pop loose and when I did get that one out sleeve and all came out
