Re: Farmall F20 Over Heating Issue
Posted by KEB on August 20, 2006 at 10:51:37 from (207.94.27.2):
In Reply to: Farmall F20 Over Heating Issue posted by WI Farmer on August 19, 2006 at 18:07:08:
Nobody mentioned checking the fan belt. The thermosiphon won't work if you can't cool the water. Had a similar problem on my Regular, turned out to be a loose fan belt, fan wasn't moving enough air. Tightened the fan belt, ran it for a couple hours, no steam.
Keith
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
