Re: 560 LPTO AND HYDRO PUMP SPEED
Posted by Wardner on August 21, 2006 at 12:59:34 from (4.154.246.174):
In Reply to: 560 LPTO AND HYDRO PUMP SPEED posted by vance stanton on August 21, 2006 at 10:59:21:
There are four gears:
SMTA/400/450 with planetary PTO .... 47 teeth
560 with planetary PTO .... 51 teeth
660 with planetary PTO .... 55 teeth
560 with clutch type PTO .... 70 teeth
These are the driven gear on the front PTO shaft. You will also have to change the driving gear up by the flywheel. Seems like you need the gear set out of the SMTA etc. Seems like they would interchange but I won't gaurantee it.
You need to take care that the gear bore is good. I have seen bad holes and it causes the gear to wobble. Prolly screws up the nearby roller bearing as well.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
