Re: 560 LPTO AND HYDRO PUMP SPEED
Posted by Dave Slater on August 21, 2006 at 18:51:50 from (205.188.116.133):
In Reply to: 560 LPTO AND HYDRO PUMP SPEED posted by vance stanton on August 21, 2006 at 10:59:21:
If your rear has the clutch type PTO you can use the PTO drive gears from a 560 that was equiped with a planet PTO to speed it up.If I remember correct about one,the PTO would turn more than 540 wide open,needed to throttle down a little.If you change gears you need to change the one on hydraulic pump also because it runs off lower PTO drive gear. Thats why even though the LPTO drive gears from a SMTA,400 or 450 would give you the right speed with a planet PTO I don't know of a gear that fits hydraulic pump to drive it from those gears.
