Re: Leaking belly pump drive seal .
Posted by john *.?-!.* cub owner on August 22, 2006 at 06:35:28 from (66.112.43.22):
In Reply to: Leaking belly pump drive seal . posted by rotax on August 22, 2006 at 05:40:23:
I've never worked on an M, but on an H which uses a similar belly pump the drive unscrews form the shaft, but requires some persuasion. It is necessary to remove the fornt part of the assembly, which contains the pump. Insert a piece of flat steel in the oil pickup at the bottom far enough up to wedge the gears, then use a bar to unscrew the drive.
