Leaking belly pump drive seal .
Posted by rotax on August 22, 2006 at 05:40:23 from (67.149.143.223):
This seal is on my 52 Super M . The belly pump is out and there is a 3 bolt flange there that appears to hold the drive shaft in the motor.
Question is that seal as easy to change as it looks or is there more to it. Is there infact a seal behind that cover ? The shaft has to come out at the same time because it has a bigger drive end for the pump than what will slide over the seal . And most important who has one and how about a part # for it .
Thanks for your help Jim
