Re: Leaking belly pump drive seal .
Posted by Andy Martin on August 22, 2006 at 08:49:20 from (64.219.39.195):
In Reply to: Re: Leaking belly pump drive seal . posted by Bob M on August 22, 2006 at 06:36:51:
I would suggest locking the PTO with a bar through a u-joint yoke (hook up your brush hog) to avoid damaging the splines.
I've had good luck with a large brass punch and a small sledge to get the coupling started.
We have broken them loose by putting the tractor in gear and setting the brakes.
