Re: Leaking belly pump drive seal .
Posted by Bob M on August 22, 2006 at 06:36:51 from (151.190.254.108):
In Reply to: Leaking belly pump drive seal . posted by rotax on August 22, 2006 at 05:40:23:
Jim - The pump drive seal is easy to change. Hardest part is getting the slotted coupling off the front end of the shaft. It screws onto the tranny countershaft with standard (right hand) threads. To remove: Engage the PTO then put a pipe wrench on it to keep it from turning. Now grab the coupling with another large pipe wrench - or place a suitable bar in the coupling slot - then tug or beat on the wrench. Once the coupling breaks free it will spin off easily by hand. Finally after the coupling is off, remove the 3 cap screws that hold the retainer to the tranny. The retainer and seal will then slide right off (the shaft will stay in place in the transmission). Tip: Drain the tranny lube level down to below the level of the countershaft before removing the seal retainer! See your CIH dealer for a replacement seal. Or take the IHC number off the old one and call your local bearing supplier. They can cross the number with a National Seal or Chicago Rawhide replacement - price is around $10 or so. Note - The replacement seal will be about 1/2 the thickness of the original. You can either get two seals and install them one behind the other. Or simply install a single seal and position it in the retainer so the seal lip rides on an unworn section of the shaft.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
