Farmall Tractors Discussion Board
Re: 706 engine swap?
Posted by RogerT on January 24, 2000 at 11:02:51 from (206.10.52.195):
In Reply to: 706 engine swap? posted by Jered Kindsfater on January 23, 2000 at 21:46:12:
no combine engines are a straight bolt up a 715(301) can be modified to fit you need a different front cover and front plate without a hydraulic pump drive, air cleaner and the carb air intake faces the wrong way. same for the 403 engine The 815 has a v8 gasengine tons of work The 310 diesel out of a tractor will work if you get the frame rails (longer) hood and Radiator (different inlet) the throttle system is also different also the air cleaner is different-The combine 310 takes more work yet
Post A Followup
: Re: Re: 706 engine swap?
