Re: farmall m wont run properly
Posted by CNKS on August 23, 2006 at 17:37:18 from (204.249.178.138):
In Reply to: farmall m wont run properly posted by derek schwarting on August 23, 2006 at 15:48:56:
Did you remove the cables from the starting switch? If so the cable that goes to the battery and the wire that goes to the ammeter have to be on the same terminal. Otherwise the engine will die when you release the switch.
