Re: Super A Transmission Problem
Posted by Hugh MacKay on August 24, 2006 at 01:19:10 from (216.208.58.137):
In Reply to: Super A Transmission Problem posted by D.R. Gray on August 23, 2006 at 21:59:46:
D.R. Gray: In the top plate with the shift lever, there are 3 shift rails. one for reverse, one for 1st and 2nd and one for 3rd and 4th. Those rails all have detent balls with springs that hold transmission in or out of a particular gear. You mention the tractor has been parked for years, thus those springs and balls could be stuck or rusted.
The first thing I would try is putting the top cover complete with shift lever and rails, submerged in a container of oil for several days. When you remove it from the oil, try shifting with cover sitting on blocks. You should be able to feel those detent balls going into detents. Should the oil not free the balls up, they are, or I should say were available from CaseIH as recently as 2 years ago.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
