Re: Eureka, I saw the inside of engine on A
Posted by El Toro on August 24, 2006 at 16:15:12 from (64.12.116.65):
In Reply to: Eureka, I saw the inside of engine on A posted by HENRY E NC on August 24, 2006 at 10:44:39:
Pour some ATF on top of those pistons and let them soak. Drain the oil and remove the pan.
Loosen the rod and main bearing caps. After 3 or 4 days of soaking remove one of rod caps and use a piece of 2X2 oak and a big hammer to drive out one of the pistons. The sleeve may come with the piston since they're not pressed into the block. That's how I did an A. I'm 73. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
