Re: OK ,I was Mad and was looking for someone to B
Posted by Jon Aller on August 26, 2006 at 05:50:54 from (71.213.225.73):
In Reply to: Re: OK ,I was Mad and was looking for someone to B posted by Magman on August 25, 2006 at 17:41:58:
I don't understand why you were trying to farm with a pulling tractor? I have built two Hs for pulling and I know that if I tried to plow, disk, grind feed or any other thing that required anything more than no load for more than fifteen minutes it would be disaster. The cooling systems on these engines were not built for continuous use at more than double the factory HP. Everyone makes mistakes and I know it is easy to be an expert after the fact.
If you want to rebuild it as a pulling engine, I could give you some tips that can make a big difference. But, you won't be able to use it for farming and have it live.
Thank you,
Jon Aller
