Re: carb kit for an H
Posted by Elk Farmer on August 27, 2006 at 17:08:00 from (64.12.116.65):
In Reply to: Re: carb kit for an H posted by RustyFarmall on August 27, 2006 at 12:06:03:
Rusty
Actually the kit did come with the packing for the high speed adjusting screw. Matter of fact you instructed me how to use the packing and thank you for the good instructions no leaks.
The tractor runs great.
I'm sure the more expensive kit has all the correct parts but the one I bought worked fine.
Carl from Michigan
third party image
