Re: Super A touch control
Posted by James Newton on August 28, 2006 at 17:33:58 from (67.14.209.111):
In Reply to: Super A touch control posted by Karl Hamson on August 28, 2006 at 15:35:09:
If that shaft is worn just a little the new seal will not work. I took mine to machine shop, they built it up with some kind of process that did not require much if any heat, then turned it down to the size of the shaft where it was not worn. Worked great after that.
