Super A touch control
Posted by Karl Hamson on August 28, 2006 at 15:35:09 from (139.142.98.95):
The touch control on my 54 super A started making funny noises every few seconds and the lift position was jerking. I had topped up the reservoir about 10 hours running time previously but it was low again. I drained about 1 quart of excess oil from the engine so I can only assume the pump is leaking into the engine oil. Is this right? The question for you good fellows is what is the procedure for removing the pump and replacing the seal. It looks like the distributor cap has to come off then remove the lines to the lift unit but then what? Does anyone know the part numbers for the seals? I do not think there is a Case IH dealer within a hundred miles of here. Thanks
