Re: Reverse operation rear frame cover
Posted by Wardner on August 29, 2006 at 07:05:07 from (4.154.241.131):
In Reply to: Re: Reverse operation rear frame cover posted by Wardner on August 29, 2006 at 07:02:20:
"P" (1946) would be more likely and consistant with what you said earlier.
