Re: Reverse operation rear frame cover
Posted by NDS on August 29, 2006 at 11:33:41 from (205.188.116.133):
In Reply to: Re: Reverse operation rear frame cover posted by JohnG(TX) on August 29, 2006 at 11:07:11:
JohnG: Your post was not showing when I posted mine even though it shows to be 20 minutes earlier. I stopped to look up numbers though.
