Re: IH B2275 Help
Posted by El Toro on August 29, 2006 at 16:37:53 from (152.163.100.65):
In Reply to: IH B2275 Help posted by Jan Larsson on August 29, 2006 at 15:00:52:
Your English is very good and the bolt torque that you are requesting isn't in any of my manuals. This appears to be a British made tractor. Someone else may have the torque specs
for the cylinder head. You need to start in the center of the head and do a criss-crossing pattern
for tightening the head bolts. You need to tighten the bolts with a speed handle or a ratchet
until they are snug. Then use a calibrated torque
wrench to tighten the bolts in graduated increases until the max torque is reached. Use the criss-crossing pattern for this too.
You may want to send an email to sales@cefs.com
to see if they have the torque spec for the cylinder head. Hal
