THANKS Andy Martin,Haas Kfox for the seal help on
Posted by Ted from Maine on August 30, 2006 at 14:44:27 from (152.163.100.65):
Thanks again guys, for all the help and info you gave me in changing my H tranny output seal,and the liftall pump input and output seals. I got them all in now. I goofed and didn,t put the lever inside the pump housing in the slotted bar on the pump and had to take the pump out and fix it. It's a long process when you use threaded rod to lower and raise the pump each time. Thanks again. Your assistance was most appreicated.
