Re: Woods mower on an H
Posted by Paul Shuler on August 30, 2006 at 18:35:15 from (170.29.248.3):
In Reply to: Woods mower on an H posted by PUTTER on August 30, 2006 at 17:47:28:
A belly mower on a H does a great job. Mine is a 6' Arts Way. You may get a little sticker shock when you start looking at mowers unless you can find a good used one. I mow about 8 acres with mine. Or I did back when we used to get rain.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
