Re: TA 400 vs: 300
Posted by Dave Slater on August 30, 2006 at 19:16:09 from (64.12.116.65):
In Reply to: TA 400 vs: 300 posted by DeWayne Utrup on August 30, 2006 at 09:50:55:
Wardner is right except for a few changes there the same parts other than transmission input shafts,the shaft bearing and thrust washer and bearing cage for shaft and bearing. From ramp and rollers to front the same. Changes along the way were the bearing on rear of planet carrier narrowed up with a thin washer used between it and rollers.It replaced wide bearing that didn't use washer. Rollers changed to crome plated and ramp change to match. Hardly ever find early parts in one now though.
