Re: No lift, no steering, no luck
Posted by Gary in Mozarks on August 30, 2006 at 20:17:09 from (64.240.21.176):
In Reply to: Re: No lift, no steering, no luck posted by Too Far Gone on August 30, 2006 at 19:24:42:
We are outside Vienna Mo. Which is close to Rolla on I-44 about half way between St Louis and Springfield.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
