Re: Grind in transmission
Posted by RustyFarmall on August 31, 2006 at 11:48:14 from (207.32.13.235):
In Reply to: Grind in transmission posted by granger on August 31, 2006 at 11:39:21:
You are turning too short, and putting the u-joints in the power shaft to the brush hog in a bind. You need to make wider turns, and if you have to turn short, stop the pto first.
