Re: oil leak 154 loboy
Posted by Nat 2 on August 31, 2006 at 12:33:15 from (64.80.108.52):
In Reply to: oil leak 154 loboy posted by stu in njo on August 31, 2006 at 12:07:25:
I would say you probably need a new rear main seal, at the very least.
The leak may be more prevalent when the tractor is working harder because the engine is hotter, and heat causes things to expand.
Another possibility that I'm totally guessing at is that your main engine bearings may be a little loose, and the extra torque required to run the mower in tall grass is causing the crankshaft to shift off to one side a little bit. Just a total off-the-wall guess on that, though...
