Re: wiring diagram for super a
Posted by Hugh MacKay on August 31, 2006 at 18:15:19 from (209.226.247.186):
In Reply to: wiring diagram for super a posted by wcroom on August 30, 2006 at 19:12:48:
wcroom: I will touch on the steering as I think you have what you need on wiring. Most of the loose steering in a Super A happens in the vertical shaft within the steering box. The half moon gear inside the box becomes loose on the shaft, and below the box the steering control arm gets loose on the shaft.
The early Super A used a square tapered shaft. I'Ve not had any experience with those but understand they can be tightened using shim stock. The later model used a round tapered shaft with woodruff keys. Usually new keys will fix those but sometimes the keyways need repair. That vertical shaft problem can give almost two complete turns of the steering wheel. You have to remove the front axle to get to the vertical shaft. The change over on that shaft occured in mid 1951.
Very rarely the steering wheel shaft will give problems in it's bearings. If you have end movement on that shaft, it will need attention. If there is no end movement I wouldn't take it apart.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
