Re: Farmall 140 Belly Blade
Posted by Hugh MacKay on August 31, 2006 at 18:28:47 from (209.226.247.186):
In Reply to: Farmall 140 Belly Blade posted by Capt Dan on August 30, 2006 at 17:25:25:
Dan: Those blades are not plentiful, compared to the numbers of tractors out there. That alone keeps them quite rare. I don't think anyone ever made an aftermarket blade that will bolt right up.
I see 5' and 6', 3 point hitch blades at TSC stores that could be very quickly modified to suit the situation you have. Basically all that blade had for mounting was a cross member between final drives, front side. Push beams from the blade pivoted from the cross member. For lifting all one needs is a lift rod up to the rock shaft.
