Re: B distributor lubrication
Posted by Hugh MacKay on September 01, 2006 at 12:19:38 from (209.226.106.84):
In Reply to: Re: B distributor lubrication posted by Jeff Peterson on September 01, 2006 at 11:05:29:
Jeff: I never bother with grease zerks, I buy the white grease in squeeze tubes. Remove the plug, and slide tip of tube in until closes the hole, and squeeze some grease in. It's quick, it's clean and easy.
Another one that folks often overlook is the fan hub oiling.
These two items tend to get overlooked by many owners of tractors with C-113 and C-123 engines. Then there is the other side, guys put Zerks in the distributor and over grease.
