Re: Widefront help
Posted by Allan In NE on September 02, 2006 at 07:45:13 from (148.78.243.26):
In Reply to: Widefront help posted by FC Andy on September 02, 2006 at 07:24:16:
FC,
I've been thru this little dance on a lot of 'em.
The key is patience and a lot of Liquid Wrench penetrating oil. As a last resort, I use two tractors to help the operation along and just "bump" the clutch on one of the tractors.
Had a 766 back in the late 70s that was the worst I've ever seen. I hooked a 966 to one side and a 5020 John Deere to the other.
You might end up using a little heat on the tie rods. Hate to use it, but sometimes ya just got to.
Just keep at it and eventually, it will come. :>)
Allan
third party image
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
