Re: Really scratching my head on this one!!HELP!!!
Posted by old on September 02, 2006 at 10:34:42 from (4.245.2.31):
In Reply to: Really scratching my head on this one!!HELP!!! posted by biggerred on September 02, 2006 at 10:15:47:
Pull the air cleaer tube off and hold you hand over the carb. Turn the engine over and see if you get gas on your hand. If you don't then you have a fuel problem. If you do it might start for you. I've had problems like your haveing and done that can the dumb things start and run well after doing that. Also doing that will tell you if you have a clogged air cleaner or a bad intake gasket
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
