Re: Really scratching my head on this one!!HELP!!!
Posted by Dave BN on September 02, 2006 at 13:28:58 from (152.163.100.65):
In Reply to: Really scratching my head on this one!!HELP!!! posted by biggerred on September 02, 2006 at 10:15:47:
If you turn it over several times and pull one of the pluggs is it dry or wet? If dry then your not getting gas to the cylinder. If wet, your not getting enough spark or incorrect timing. You can try putting a small amount of gas in each plug hole using a squirt gun, etc, put the plugs back in finger tight and see if it will at least fire. Also, have you checked the oil level? If the crank case if full of gas or watter it won't start. Dave.
PS Carefull around the gas!
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
