Re: Really scratching my head on this one!!HELP!!!
Posted by nsmall21 on September 02, 2006 at 18:19:44 from (204.10.160.32):
In Reply to: Really scratching my head on this one!!HELP!!! posted by biggerred on September 02, 2006 at 10:15:47:
hey, i actually had the same thing happen on a 140 friday. i tracked it down to a wire coming from the regulator to the ignition switch. the insulation was checked and cracked. i had a little fire at the points after changing everything i could in the distributor, and a little at the plugs every now and then. turns out that wire and the one going to the coil were on the same post on the switch, and the cracked wire was an easier ground than going through the distributor. so i replaced the wire from switch to regulator and it runs like it used to. hope this helps. nate
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
