Re: Farmall H Carb Problems?
Posted by MAGMAN on September 03, 2006 at 06:27:03 from (67.142.130.37):
In Reply to: Farmall H Carb Problems? posted by Stevishere on September 03, 2006 at 05:37:02:
Alot of the times when this happens its becuase you did not get the carb clean enough you can soak them untill the cows come homes 6 times and blow them out and everything but unless you take a small piece of wire and work every little hole and orfice and use spray cleaner and such sometimes you dont get them all clean. This is the biggest culpret for a carb that will not adjust when you get it rebuilt. But yes check for the vacum leak first. But most of the time they will run different from cold to hot when the intake is leaking.
JON
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
