Farmall H Carb Problems?
Posted by Stevishere on September 03, 2006 at 05:37:02 from (208.53.111.226):
I have a gas 1940 Farmall H. Could not get it to run without almost full choke. I verified govenor adjustments as correct. I rebuilt the carb. Started right up with choke open. It surges at idle unless I close the choke about 1/4 of the way. Neither the idle mixture screw or the main jet screw seem ot have any effect on the way it runs. Any ideas?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
