Re: Making gaskets
Posted by MI Mark on September 03, 2006 at 15:22:17 from (152.163.100.65):
In Reply to: Making gaskets posted by MAGMAN on September 03, 2006 at 14:05:30:
for gaskets I just trace the old gasket if theres enugh to do so thenfree hand them for the bolt holes just use a paper punch over the waste basket so as not to clean up a mess if there not perfet where it can be big or small some oh well for the biger bolt holes like for a 5/16and up a carrige head bolt will do just fine to cut nice neat holes put the gasket in place then with the head of the bolt on the gasket wher e the blot hole needs to go juat tap the stem of the bolt setting on the hole foe the blot or you could drill the rihgt size in a steel plate then use that for a die.
