Re: Farmall H Carb Problems?
Posted by Roger46 on September 03, 2006 at 17:26:19 from (69.58.130.137):
In Reply to: Farmall H Carb Problems? posted by Stevishere on September 03, 2006 at 05:37:02:
Sometimes I think no matter how clean you think you have everything in the carb there still is some small piece of dirt in there someplace hiding to cause you problems when you start the tractor. I just rebuilt the carb on my Super H a couple weeks ago including soaking it in carb cleaner, blowing out all the passages, and spaying a second time with carb cleaner and blowing out again. I went out to mow and the tractor acted like it was out of gas when I put it under a load. Then it seemed to clear itself. This week I was mowing some tough weeds and stuff for the neighbor and the tractor ran perfect. I shut off the tractor before driving home and when I restarted it, it would start and then die. It did that several times and then ran OK. Now I am gun shy about using it away from home. Roger
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
